2 hours later…it is done. No thanks to the lackluster instructions. I ordered the 9004 hi/low kit and none of the instructions on the website reference the blue plug or the 3 wires (brown, yellow and blue).
That blue plug was actually part of the install. The PDF directions I downloaded made no mention of it. No one in the youtube videos ever used it either. My frickin luck I get the one kit that has no instructions on how to wire up those 3 wires with the car for signal. These goofballs use the brown wire for ground and the blue and yellow for high-beam and low-beam signal. Didn’t find that out until I had already wrapped them all in elec. tape and wrapped/tied them all…thinking that I didn’t need them.
So I go to turn the lights on after doing all that and…nothing. No blip, no flash…nothing. So I call customer support.
Some kid picks up and says “DDM Tuning customer support, how can I help you?”
I proceed to tell him that the downloaded instructions from the site don’t offer any help on what to do with the 3 wires and the blue plug. This kid has the nerve to tell me to go to the website and check the support page… I interrupted him mid-sentence and blasted him “I’M NOWHERE NEAR THE FRICKIN INTERNET! YOU ARE CUSTOMER SUPPORT, START SUPPORTING MY ASS AND TELL ME HOW THIS FRICKIN BLUE PLUG AND 3 WIRES WORK!”.
I hear him typing on his computer and then he tells me “The brown is the ground and goes in the middle and the other two wires are the signal wires that can go on either side. If you stick the blue on the left side and the yellow on the right inside the stock bulb harness and everything works okay you’re golden and you can put the wires into the blue housing in the same fashion so that they connect permanently.”
I say “Thank you, was that so hard? Have a great day!”
So after all that, the light on the driver side still wouldn’t work, I figured that using the ground that the valve cover is connected to was a dicey choice. So I spliced the ground wire for the drivers side with a longer wire and ran it over to the other ground wire on the harness that is running directly to the battery.
BAM! Both lights FINALLY work (In the driveway). But now I’m thinking that if that ground to the valve cover wasn’t working for the lights, it probably isn’t working for the valve cover either. I will have to find a metal drill bit and drill a new hole in the subframe somewhere to ground the valve cover properly.
<The next day I actually drive with them>
Here they are when you turn them on…
10 seconds later…
Oh look, that explains a bit…
So now I’ve gotta see if I can make a new ground spot that the stock wire will reach to. Even though I’ve spliced into the ground and run it over to the battery, it still wont’ work.
Dm of mD
