There is no reason a starter can’t last 15 years or more, if you are not hearing the starter relay click when you turn the ign. switch to start, then, as I said, the problem is not the starter, it has to be before the starter.
To confirm that it is not the starter or the starter solenoid, unplug the starter wire from the solenoid, then us a jumper wire and
supply power directly to that terminal on the starter motor/solenoid, [that you unplugged the starter wire from] from the batt. pos,(+), make sure car is NOT IN GEAR, if motor turns over it will confirm that the problem is not at the starter motor/solenoid.
The problem must be before there, in one of the things I mentioned before.
There is really no point in starting to replace things until you know what needs to be replaced.
Do you have a multimeter or even a 12V test light?
There are a few tests, [bypasses] you can do to find the problem.
Start by pulling the HU out, you should be able to access the starter relay without pulling the console, I beleave the relay is mounted, [in a G2] to the dash sub frame below the HU, [and pocket] and has a 3 wire plug, 2 black/white leads, [starter wire] and 1, much smaller gauge, black/blue, or blue/black lead, [clutch interlock switch], if you have a meter or test light, check for power on the black/white leads when you turn ign. to start.
If you have no power on either of black/white leads, it’s a good bet the problem is the ign. switch.
If you do have power on one of them, check for a ground on the thinner clutch interlock lead, when you step on the clutch.
You can also just use a jumper lead from ground to the thinner clutch interlock switch lead, just stuff one end of jumper into plug/terminal with the thinner clutch interlock lead and ground the other end to the chassis. or metal dash sub frame, if car starts, the problem is the clutch interlock switch, will need to replace the switch, [mounted high on clutch lever], you can temporarily bypass it by unplugging it and use a jumper to connect the black lead, [ground input] to the black/blue or blue/black, or you can just leave the jumper in the starter relay.
You can also bypass both the relay and clutch interlock switch by unplugging the relay and installing a jumper between the 2 black/white leads in the plug.:bowthank: 94
