Does this seem like a good set-up
And also what do you guys think its worth… the whole kit here its been used one season.
Meutek cast mani, flanged for a tial 35/38mm wastegate
has lifetime guarantee and will never crack like a welded manifold could
Garrett T3/T04E 57 Trim .63 ar Turbo
Good for well over 400Whp
Both pressure and return oil lines included, with fittings/flanges
2.5" charge piping, mild steel painted flat black
Couplers and T-bolt clamps included
Piping will allow for windshield washer bottle to remain in an EK/EJ civic
SSAC Precision 350 knock off intercooler, painted flat black
Tial 38mm WG
With a small green spring - 7.2 psi
monza SSQV BOV
3" Downpipe mated with a 3" DMH cut-out (Runs through stock exhaust when closed, and open down pipe when open)
Chipped non vtec ecu
This kit made 302Whp/262wtq @ 12lbs on a stock ls
Thanks for the help
I personally hate that manifold. But I would definetly get a bigger exhaust. Even doe your using the e-cut out.
I didnt buy it… its being sold… just wondering if you think its a good set up and what it would be worth…
how much do they want for it?
1500 canadian …
its been used for one season.
