down pipe fitment
well Im really close to buying all the parts I need to bost my teg but I have a question about the downpipe and the crossmember that is right under the motor. Will it need to be removed? notched or will a DP fit past it? does it matter which side the DP comes off the turbo? Thanks
notched mine with a rotozip bit on my dremel tool took all of twenty minutes…
either side wont matter aslong as it meets the rest of ur exhaust i guess
no it doesnt need to be removed
i made my own dp and it fits perfectly, i needed to make a pie peice cut but it works, no reason to remove/cut it
