I’m thinking about turbo charging my integra and i have a few questions about a couple of the kits that I’m looking at. I read that the Drag kit does not have an air filter, is this true? I’m also looking at the Ballistic turbo kit which is not intercooled. I have done research into turbos and understand how everything works. How stressful would it be on my teg if i went with a non-intercooled kit?
You obviously haven’t done your research. Sorry. I’m not one of those people on this boards that just freak out and say “search”
- but still man… non-intercooled… if you’ve read up on turbos, you’d know you can only safely run like 5lbs of boost max… if that… you’re intake charge would be so hot… blah. Next time read more before you post.
the drag kit does not come with an air filter.
I plan on running a small pipe with an HKS mushroom filter
for under 7psi you don’t really need an intercooler but its a good idea. especially if you want to boost higher levels in the future
