Drag manifold + turbo bolting ?'s
i couldnt quit pinpoint in a search, you may delete this post later.
But will a TD05H or t3 line up and bolt to the drag manifold?
Unsure of the TD05H, but the T3 will.
td05h is the compressor housing on a mitsu turbo. compressor housings do not bolt up to manifolds. just letting ya know. but mitsu turbos will not bolt up to drag manifolds.
hey thanks formz, isnt there some sort of conversion i can buy?
you have two options: adapter plate (garbage)
cut the flange off and weld on a new one (better)
