DRAG opinions
Im about to order a manifold, downpipe, turbo and IC>
does anyone have anything bad to say about the DRAG stuff
or should i buy these same 4 things from say FMAX or REVHARD instead
the rest of the pipes will be made and i have hondata
My goal is 15 psi
please give me some opinions what kits are you running and do the manifold/turbo fit well
thanks. CHRIS
I’m runnin the DRAG kit, mostly because of the convenience of have everything I needed to pretty much bolt on and go. Also, DRAG allows you to retain your A/C. I/C’s are pretty universal-DRAG runs SPEARCO’s. Rev Hard makes some quality manifolds, as well. Guys on the boards who fabricated their own piping, can tell you what your lookin at as far as that goes. Downpipe, again can either be custom fit or ordered. Mine required a flex pipe to line up correctly to my exhaust, though.
