EF rack swap question
vss is the vehicle speed sensor. It drops into your trans. and connects via a cable right into your speedometer. As explained in this post, you can either use your existing vss and “loop” the lines that go to it or use a Civic Si sensor which only uses the vss cable. Does that make sense? G2guru let me know when you have these ready to go and I will paypal you!!
X2:hyper:
Dan, Did you get that measurment I sent you?
sent a message… also interested in this custom bushing… :rockon:
bump
Good and bad news for all that are interested. I have been so busy at work I have had no time to do these bushings myself. So I am having 10 sets turned out of the shop. I should have them by the end of this month. That’s the good news. The bad news is that the price is going up to $30 shipped. I hope you guys can understand. I’m actually only making $5 per set. The rest is going to the machine shop for materials and machining costs as well as shipping. I will post pictures of the finished product. First come first serve. I may be willing to do another order down the road once things slow down a bit at work but don’t hold your breath! :slight_smile:
I need to know as soon as theyre available, i need to get a set. $30 shipped is no problem for me, it will be ready to go…please email richter427 at yahoo (or hotmail) .com , as soon as you get them, Thanks.
I’m definitely down for a set, and I know Gylnn is!
Sign me up, paypal ready!
So all sets are spoken for:
BLKACK1 -Option 3
Dakine702
white92LS531 -Option 3
mrpenny -Option 3
ONE-R -Option 3
mugendaxsi -Option 3
darussianone -Option 3
CerealKiller90
Poser714 -Option 3
TWIZIDY -Option 3
I have 0 sets left. The shop called for a finish date of the first of August. But they usually finish a bit early. Sorry it’s taken me so long to get on the ball here. If you haven’t already pick yourself up a set of the DA Energy Suspension PS Rack Bushing set to go with this. The combination of that and the aluminum bushings make a big difference in steering feel with the EF rack.
Dan,
Add me to the list please, Thanks.
Angell
Done!
i would like one tell me when an were to paypal you please
As I doubt I will have a problem moving these no money is required to request a set. Even if the people who “requested” a set don’t follow through with payment, these parts will move quickly. Once they are finished and I can verify that the parts were made to specifications, then I will accept Paypal payments. Payments will be made to g2guru@comcast.net . Please be sure to include your G2IC screen name as well as your current mailing address. I’ll be sending them USPS Priority Mail.
interested…
add me to the list dan!
Done. There is definitely one set still available and maybe 4 (depending on if the others are still interested. If your name is on the list with no notes following, a set has been reserved for ya!
WHOT, WHOT :clap:
i would like one you did not put my name on the list can you please add it
All sets are spoken for unless the three people that were interested are no longer interested. If you are still interested even though I have none left of this run, let me know and I may start up another one.
:rockon: Thanks Dan!
I was still a bit undecided about doing the manual rack for a daily, but this just sealed the deal for me.
