[QUOTE=mR_InTeGRa;1770435]my old DA with EK skirts… pics are in threads around here somewhere but ill just post them again…
for those that are wondering… they are being held up by 2 screws in the rear… and the rest are from underneath…[/QUOTE]
i know its been said “EK” sides but these look like dcs am i right? cause i like the look of these
[QUOTE=Twizo;1462079]i got ek sides
heres when i mounted them last summer
as far as mounting them u first have to do alot of cutting
…after u fit them either u buy clamps or someshit i couldnt wait so i jus drilled them in[/QUOTE]
here u go… good luck getting them to perfect like this car… i had ek sideskirts on my DA and it was a pain in the ass and never came out as good as these ones… hopefully you have better luck… this is the car that inspired me to run those skirts… just wasnt as easy as i thought it’d be… so i took em off after a couple years.
I can post up a “decent” install of EK 96-00 Coupe Side skirts on a Acura Integra 4 door sedan (DB1)
This is my 1991 Acura Integra Db1
These are my 1997 Honda Civic Coupe side skirts
You have to prep the Honda Civic Side skirts for install. - You have to cut the little tabs along the inside of the skirt.
-This is the pieces that SHOULD be cut off. Here is what they should look like off the Civic side Skirt.
Install of 96-00 Honda (Ek) OEM side skirts to Db1 chassis -Remove your Integra mud flaps (insert sad face here)
-Simply lay the side skit on the side, you do have to open the doors for this to fit onto the side. You will notice the Honda Civic EK side skirt is a tad to long. As you can see in picture.
-You will notice the side does not fit flush, like you would want it. This is a simple fix. Just trim the Honda Civic EK side skirt to fit in this area. I boxed it in BLUE of the area that will need to be trimmed. Keep in mind, the more time spent, is the best results.
-Here is a pictures of the Civic side skirt fully trimmed. I did not spend a hole lot of time on it. I had important things to do. :stare:
-Here is a rear picture of the Honda Civic side skirt fitted onto the side of the DB1 chassis.
-Your Screw placement for the Honda Civic side skirt on the Acura Integra DB1 Chassis
-Rear install, SUPER simple. Just drill a small screw here. Ladies like pink…
Installed!
My door is dented!
NO, You are not done yet. You plan to leave the ends open? Pshh…You will need some Accord front mud flaps. The accord mud flaps have an indention where the side skirt can lay, for a clean install!
