[QUOTE=DA_all_day;2319578]looking at the vacuum diagram above:
delete the dashpot, airboost valve, charcoal canister and both solenoid valves.
as far as what vacuum lines to run where, run a line from the map sensor to one of the two open nipples on the driver side of the intake manifold and run a vacuum line from the fpr to the other nipple. you don’t HAVE to use the ones on the back of the intake manifold. just run them to wherever is open. they just need to see a vacuum source
any open nipples after removing the components can be blocked with vacuum caps… done and done[/QUOTE]
Seems simple enough. I just wish I knew exactly what those solenoid valves on the firewall do especially considering they have a wired plug going to them. I know it doesnt matter but im just curious why Honda didnt just vent directly into the manifold?? The guy who designed these solenoid valves must have also been the one to put the oil filter in the middle of the back of the block… that idiot!!!
Just a minute ago I had the car running and unplugged the plug to the solenoid valves and it didnt throw a light or seem to effect the running. Im assuming these valves (one connects from the charcoal canister and the other from the FPR are just fumes that the solenoid valves release back into the manifold directly in a controlled manor, rather than just a direct vent. Maybe once so much pressure builds they release? I also dont mind having the charcoal canister there because you cant really see it so ill just vent into the manifold.
I think I will just run the vacuum hose from the charcoal canister directly to the nipple on the driver side of the manifold where the solenoid previously vented. Ill also vent the FPR directly to the back of the manifold to the other nipple and possibly split the MAP into that vacuum line. Then hide the plug for the solenoid valve somewhere.
Also has there been any solution to plugging the air-boost valve? It seems if you took that off you would need some sort of plug that.
[QUOTE=Denied;2319601]http://forums.g2ic.com/showthread.php?185951-The-DA-wire-tuck-write-up
The above link helped me out heaps, altho im not planning on going all out on mine, just a basic tidy up… lol, well i say that. [/QUOTE]
Dang I could look at that thread all day. Im not looking to go that crazy (Although Im sure that’ll change once I start, haha) but it would be nice to get rid of some of the meaningless stuff though. I may look into routing the headlight harness under the fenders to clean that up. Otherwise Ill just button up small things here and there.
You guys are a huge help as always
