Thanks.
So after driving the car this past weekend I learned two things. One, the car officially has NO leaks anymore =]!!! I couldn’t be happier about that. And two, the car is staying on 6psi and going back onto the stock map sensor…=[
I’m gonna contradict myself here from what I said previously, but the realization has set in.
I wanted the car to be on at least 10psi. I said doing all this turbo stuff would be pointless at anything less than 10. Well…I change my mind. There are certain mods that just aren’t up to the task of handling 10+ psi right now. The clutch, the tires, and the biggest one of all…my tuning.
I know this is going to sound strange, but I was having way more fun with the car when it was only on 6psi. I didn’t have to worry about the clutch slipping. I didn’t have to wait until I was going fast enough to prevent the tires from spinning. On 6psi I could get on it at low speeds in 1st and 2nd gear and pull without issues and it was a blast. Upping the boost was just too much for right now. Obviously the clutch couldn’t handle it, but also not being able to get on it at low speeds because of the tires sucked. What’s the fun of only being able to really get on it at certain speeds or on certain types of pavement. 6psi I could get on it anywhere, anytime, any gear and it did nothing but put a big smile on my face.
Back to my point about contracting myself saying “it’s pointless to go through the effort of boosting the car to not have it on at least 10psi”. Like I said I’ve changed my mind. The point of boosting the car was to have fun and to enjoy it as much as possible. I want the car to put a smile on my face when I drive it. If that means running a lower boost pressure than I wanted, then so be it.
Now onto the issue of my tuning at higher boost. I’m not dumb when it comes to tuning. I clearly I don’t know everything and I never will, but I’ve had a few years of experience tuning my car n/a, then n/a e85, now boosted e85. It’s not all that complicated when the concepts are thoroughly understood. What makes it complicated is how you go about doing it. This pulling the chip each time and making educated guesses and adjustments just can’t cut it for higher boost levels. Things happen WAY too fast and without any real way of data logging to look back on each time, or seeing things in real time as I’m driving it’s damn near impossible to get it done with any real degree of accuracy.
I’m not knocking or blaming Crome for this. That is a good program and with all the proper equipment to impalement real time tuning and data logging I’m sure it would be a lot easier. I just don’t see the point in me buying all the needed stuff for it when I could just buy Hondata and it’s all in one package. That being said I’m throwing in my towel on tuning my car myself on Crome. :surrend: I’m just completely sick of having to do it the way I do. It’s time to buy Hondata.
It’s also time to part ways with one of my favorite and very special parts on my car…:pupeyes:
I’m about 90% sure I will be putting my RSR Exmag cat back up for sale soon. It’s the full stainless polished version.
It’s on the car still, but is doing absolutely nothing right now because I’m open downpipe. It’s too small for turbo applications and I think it’s a waste being on a car and not being used. I hate to get rid of it because its one of those items that’s so hard to come across, but at the same time I feel it deserves to get used. I feel its time to let someone else enjoy it as much as I did.
I’ve got a rough idea of what I can get for it, but I’m gonna pull it off and see what condition it’s in first.
