Does anyone make a firewall mounted MAP sensor with a 3 bar or so inside? I have a GM 3 bar but would like to run a stock appearing one to keep it clean. Don’t want to redo the wiring to run a TB mounted one either.
No one makes any oem-looking map sensors for the EF/DA. Your only option other than swapping to a TB-mounted sensor (which I highly recommend; it’s not that hard), is to do what this guy did:
http://www.realhomemadeturbo.com/forum/index.php/topic,9870.0.html
