Can I safely run 5.5 psi with just dsm 390cc injectors and a fpr?
Those injectors are more than enough…you should be able to run 15psi with those injectors…you’ll need a boost dependent FPR…good luck
HEY Haberdasher! what psi are you running are that teg? nice setup!.. later
I’m running 12psi very conservativly tuned…
when you say conservativly tuned, explain what you mean… if you dont mind? do you tune alot? and what all do you look over for tuning…tia
