Hey guys I was talking to a shop about going turbo for my motor and they said full race put out the best turbo kit on the market with the GT35R. I was curious of peoples thoughts on it and if anyone has ran it?
i would run a full race kit if i had the money for it. a stage3 kit with a gt35r option is goin to run you around $4500 to 5000 thats without pistons and rods.
how much horsepower do u want?
turbo kit stage 3 600hp version $4500 full race (gt35r option)
ems hondata or neptune or AEM 400 and up AEM being $1300
injectors 1000cc 350 400
injector driver box ?
piston and rods cp pistons and manley rods 1200
type r oil pump $75
arp head bolts $125
stock head gasket $60
fuel rail 150 and regulator 85 and up
fuel pump 90
clutch kit to hold 600 hp (twin disk 1000)
guages oil pressure 65, uego 279 , boost 55
suspension setup
there is more
boost controller
3 in exhaust from dp back $500
valve train springs, retainers, guides, valves 500
dyno tune anywhere from 100 an hour up
labor and all the lil things that come up along the way
yes u can install that kit on a stock block just dont expect to get 600 hp
and probably on run it on 7psi. and who would by a fullrace kit and only run it at 7 psi.
buy a full-race kit should mean automatically to build the motor to handle the horsepowere it will put out.
I am building the motor I will be looking to start with about 350 HP at the wheels and go up from there. some parts I have right now are:
3" Thermal R&D Exhaust
B18C1 Sleeved block
B16 Head
B16 Cams
Eagle 5.967" Rods
Quaife LSD
JG Edelbrock victor X manifold
MSD Digital 6
soon to be getting custom pistons
B18C1 Crank
3" down pipe AC Compatable
Nos Kit
Cosmetic Head gasket
Fuel Rail
Moroso Oil Pan
Cam Gears
Co2 fuel cooler (if i decide to use it)
that some of the parts Money is NOT an issue here I want to do this and do it right.
looks like your on to a real good build. Put that fullrace kit on and feel the power of the darkside.
