I have had my teg for a year and it is time to boost, What would the difference be between using a 1/2 size radiator and ic with backdoor compaired to using the full size radiator and a larger ic. My turbine is on the passenger side and I am planning on keeping my a/c. I can live with out the power steering, so any imput for the effectiveness on keeping the car cool and the preformance of the turbo. I am running a t3/t4 on a log style manifold. Thanks.
i kept the full size.had to lose the power steering, although im sure i could of kept it.
i have a t3/to4e on a drag log style manifold
I’d stick to a full size rad no matter what unless you MUST convert to 1/2 because of manifold/turbo placement and so forth.
Full and i kept my P/S
Full rad here too
^^i thought you had a half sized fluidyne?
I do. this is a pic of the full rad. SHHHHH
do you have any pics of you ic piping? did you also keep your ac?
thanks
thanks for everones input.
[QUOTE=acuraspeed2]i kept the full size.had to lose the power steering, although im sure i could of kept it.
how much difference does it make not having the p/s? my teg is an everyday town driver and my toy.
^^ill let you know when i drive the car this spring lol
actually you can keep the power steering. i was just out in the garage and my pump will just clear. so i am happy
i just need to move the resovoir out of the way
I’d keep power steering, but you can drive without it. I prefer to have it for daily driving. Is it possible to use the log style? I’m not sure it that’s what the one is that has 2 side to side runners, but that’s the one i’m referring to.
Any pics I have are on my site…but I did have to drill through the frame where the washer fluid bottle was, and relocate my horns.
I did not keep A/C
