g2 b18a/b turbo with full rad + aC anyone?
having problems with my setup
cant put a fan on ac side…if i do theres no room to snake the turbo piping in!
how bout using some slim fans???
thats still a problem
imma try a 10 tomaro
on the ac side
spooling give me 2 12s hehe
bTW is it ok if i move the fans to the LEFT ALOT
to make room from the rad>compressor/lines
if you buy a 9" slim fan to replace the AC fan, you can put it on the condenser side. I have my fan set up like that and no cooling problems.
also, if you want to move the radiator fan to the condenser side, the biggest fan that will fit is a slim 10". i am actually running both my fans on the condenser side to clear some space. HTH
theres no way to put a fan on condensor from the front
what do u mean?
i am actually running my fans like this. and i have been running like this for about 6 months. i’m saying you can fit a 9" slim fan right in front of the condenser on the same side the original AC fan is on. it fits very snug right in between the middle support that the hood lock is bolted to and the inner corner of the headlight.
so u mean dont run it at the stock location up front but move it more toward the passengerside?
does it matter if it overlaps the puller fan?
no, right now, i have both fans on the condenser side. when facing the front of the car, the 10" is on the left and the 9" is on the right. there are no fans on the engine side.
how did u managed that?
its so cramped back there with the AC LINES(the coil ones)
