I have a few question that I need help on. I was wondering would I run into any problems once I go boost from my car being to low. I’m getting a t3/t4 hybrid turbo with a a/r 50 compressor housing and a a/r 63 exhaust side. And also I’m getting a Hondata S300 with a p72 and wanted to know if it would work on my 1992 GSR. Let me get some feed backs thanks.
ride height has nothing to do with boost…unless you keep bottoming out your downpipe
you’ll scrape your downpipe and exhaust pretty often but besides that you should be alright. depends mainly on how nice the roads are in your area. i had about the same drop with a 300whp setup and 3" exhaust and scraped my resonator and flexpipe pretty often but the roads around here are seriously the worst roads you’ll ever see in north america.
my cars boosted at that height, you might scrape little bit over speed bumps, but a lot of it depends on how the DP is made, as well as pipe diameter… GL on build:up:
