I am ordering parts for my first turbo build. My question is… could I use the
“Golden Eagle Oil Sandwich Plate” instead of drilling a hole in the oil pan and tapping it? Also what size adaptor would I have to use for he oil return line?
thanks for any help
im pretty sure the oil sandwich plate you are talking about is for oil feed not oil return, their sandwich plate gets the oil to you turbo/vtec application and has nothing to do with the oil return, you would still need to drill and put a fitting into your pan for the oil return
http://www.goldeneaglemfg.com/street.html
the sandwich is for the LS/VTEC conversion only
Thanks for the reply guys.
