Good wideband gauge?
Was looking at getting all GlowShift gauges, and I need a wideband one. So instead of getting the AEM Uego one and my boost and oil pressure ones from GlowShift, would this one be as comparable to keep all gauges uniform? The price is similar, maybe like 20 bucks cheaper, so I’m assuming it should be decent quality.
http://www.glowshiftdirect.com/Black-Face-Wideband-Air-Fuel-Gauge.aspx
Or go with this Autometer wideband and get 2 matching Autometer gauges? http://www.summitracing.com/parts/ATM-3378
Any insight?
Coz
get the aem. its the best one out there by far…
You could always go with the PLX DM-100 or the larger DM-200. Start with a wideband, add the boost and oil pressure modules and you have 3 gauges in one. PLX also makes a good wideband.
I use a innovate LM-1. You can get a LC-1 cheap on ebay.
i got the plx m300 better then the aem one
I like the M300 also, I wish the Tuner Edition wasn’t ugly as hell.
I know a couple people running the innovate LC1 w/ DB blue or Red guage that xenocron sells. Heard nothing but good things, i plan on running it on my setup and its a decent price around $220
Ive been running a PLX DM100 with the wide band and AF for about 8 months with no problems easy install and was able to sub out the narrow band o2
i use the innovate lc1 with the db blue gauge. no problems with it works very well.
Got the AEM UEGO Wideband.
Thanks guys.
Coz
Little late on the reply but any is really good. The fact is that most of the Widebands run the same sensor. It is the Bosch LSU 4.2. The only one that does not is the Glow shift which runs the newer LSU 4.9 which is a heated version of the 4.2.
When picking a setup it is more of what type software you want to run or what you feel comfy with. However no one should be anymore accurate then another with the exception of the Glow Shift being able to get a faster reading.
I got the LC-1 for $185 shipped, NEW.
