gt35r turbo review
Sorry for the nub question but I have search and cant find anything that i was really looking for. Does someone know when the gt35r would spool? Do you all think that they are worth the money? I have found a cheap replica one on ebay and was wondering if you all think it would be ok or a piece of shit.
the ebay turbo
I would be putting it on a nearly stock integra. Thanks.
A GT35r on a stock LS? Too much for that application…those turbos are made to flow enough to make 400-600 HP on a 1.8L-ish motor.
Look at a smaller BB turbo if you need to go that baller on a stock block LS.
GT28rs
GT2871
I think there are some nice dyno graphs on Boosted-Hybrid’s site with those sorts of things…
http://forums.evans-tuning.com/viewforum.php?f=5&sid=6c4ce54961f91920c810852a38871063
Couldnt have said it any better. Find a complete kit since your car is stock
i gave a t4 gt35R on a b18c1 and i hit full boost 25psi at 5600rpm
Thanks for the info but does anyone know when the GT28rs or the GT2871 hit full boost? Thanks again.
Depending on what exhaust size you use on the turbine, you should hit full boost around 3000-4000rpm with teh GT28RS. the GT2871R will obviosuly spool a little bit slower.
My roommate has a gt28rs with the .86 a/r hot side and he hits full 21 psi at around 4600. This is on a nissan ca18, so it may be slightly different for you, but it’s still a 1.8L and fairly similar.
On a honda 1.8 they generally spool faster then that. most 1.8’s stock witht he .82 t3 drop in hit full boost around 4000 at most. Seen soem as low as 3500 witht he .82. On the .63, I could see 3000-3500
