Help for radiator and mani
Hi guys I’m new to g2ic and thanks for your advices from now :slight_smile:
I’m living in Europe and I have 91 4 door integra. My setup is;
b18b Block
b16a stock head
84mm darton sleeves
84mm wiseco pistons
Eagle H-Beam Rods with arp bolts
ARP head and main cap studs
Cometic Headgasket
OEM Rod and Main Bearings
T3/to4e 57 trim 60ar turbo
38mm Tial Wastegate
b16 Tranny
Competiton Clutch Stage 4 clutch Kit
Exedy Ultralight Steel Flywhell 9 lbs
AEM ems
750cc RC injectors
Gm 3bar map sensor
Gm boost selenoid
XS Engineering 13lt Intercooler
This is my setup :slight_smile: , I didin’t buy the manifold, IC piping and radiator and I have few questions about them.
First did anyone used treadstone IC piping kit because I’m thinking of buying from them.I mailed them and they confirmed that they have piping kit for DA.
http://www.treadstoneperformance.com/product.phtml?p=149&cat_key=54&prodname=Acura+Integra+Aluminum+Intercooler+Piping+Kit
Second I can’t decide on turbo manifold because I want to use full size radiator, I can’t decide weather to buy ramhorn or mini ram. I have seen some people running full size radators with tubular manifold how this can be possible ? also I want the inteake side of the turbo on drivers side not passenger side.
Third is it possible to relocate the orginal radiator, I mean can the bottom or upper mounts of the radiator madified so that it can be moved to front of the car alittle ? I’m asking this because of the clearance problems.
In summary I want to use orginal radiator so I make make my manifold choice according to it. IF it not possible tham I will go with ramhorn manifold and aftermarket aluminum halfsize radiator but it last choice for me because of the high cost
I’m waiting for advices also sorry for the bad language.
Running full size rad and fan with my setup, hope it gives you a bit of an idea for how much room your lookin at.
Matt that looks like a fuckin knot it a rope :cookie:
lol yea and works great
What is that mani ? As I sad I’m looking for miniram or ramhorn I haven’t seen a mani like that.
It was custom made at Kinetic motorsports a few years back.
Any other advices ?
Thanks Mattv but I don’t think that I can order custom manifold.
mani and rads are a #BEEP# to fit in our cars I use the short runner log style mani in my car like DRag and Blox that works and I can run a GSR Radiator with a slim fan
