he guys, anyone have the factory wiring diagram for under the dash, I am trying to wire up a HKS TYPE 0 turbo timer
Thanks in advance,
Jeff
Thanks in advance,
Jeff
ttt
Ok finally got the TT wired up. Here is the info:
From Turbo Timer - to Ignition
Red wire - White wire
Green wire - Black wire yellow stripe
Blue wire - Yellow wire
Also here is a website with some pics:
http://importnut.net/turbotimer.htm
aahhh, the glory of figuring it out on your own.
Thanks.
BTW did you happen to figur out where the RPM signal wire goes to? can i just tap it into my exsisting tach wire that comes from the negative side of the coil?
Jeff
Originally posted by turboteg1.8
[B]Thanks.
Jeff [/B]
Yep, I’ve got a Autometer monster tach w/shiftlight. I just spliced that wire and it sent the signal just fine to the TT.
BTW what color wire is the e brack sensor wire on the factory harness?
Thanks again, i got it up and working except for those 2 wires
Jeff
[B]BTW what color wire is the e brack sensor wire on the factory harness?
Jeff [/B]
Man I’m away from my car for the weekend, but I wanna say it was green w/red stripe.
The ecu pin out is C10
C plug is the plug on the top; its black and smaller. (not the big white one.)
count the wires in the plug from top to bottom:
1 3 5 7 9 11 13
2 4 6 8 10 12 14
When I get back on monday I’ll give you more info.
good luck
thanks, brotha i got it up and rollin, fully functioning
Jeff
sweet, glad I could help out. I’ll be emailing you soon about turbo stuff.
later,
Orlando
i know this is old but
archivethis
is the type-0 same as the us-spec type-1?
mine is an older version, but has 6 wires comming out of it.
here’s my thread, help would be greatly appreciated…
and also, that link that was posted about the install, is for a GReddy turbo timer, would it be similar/same for the HKS one?
hey bro, sorry for taking so long to get back to you, the wiring is almost identical, that’s what i used when i wired up my hks type0 and i think the type 1 wiring is identical
ok, thanks… it’s still not hooked up, but it’s mounted, and i already took my old turbo kit off… hahaha
so i’ve got something to work on now…
thanks for the reply back…
hooked it up, and it doesnt let go of my key until it shuts down, (countdown, ebrake, or power button)
i dont know what’s going on.
