I have a t3/t4 turbo installed and i am working on the oil lines right now…
I just finished installing the morasso oil pan and have the oil lines hooked up to the taps on that, Do i just run the lines directly from that to the turbo? Any help would be great!Thanks in advanced.
Chaz
the feed line DOES NOT come from the oil pan, only the return line. you have to get a sanwich adapter plate or T fitting for the back of the block for the feed line.
http://www.beesandgoats.com/boostfaq/g2icturbo.html
i used earls t fitting and used the stock oil pressure sensor hole. works like a charm.
