hey guys, I was just wondering where the best place is to tap into for water lines… I tapped into the lines going to and from my heater core, but I’m not sure if there is any specific flow direction or if it doesn’t matter?? the water line at the back of my turbo runs to the heater core outlet line, and the line at the front of my turbo is running to the line going into the heater core (before the water ****, so it will get water regardless)…do you guys have yours hooked up the same way? or am I backwards?
I don’t think any of use are using water cooled turbos…
u can unhook the lines going to your throttle body & use those lines for the turbo.
That’s a good idea…only problem would be the length of hose going from TB to turbo and back again…
well, I’ve already cut into my heater core hoses… but for some reason, one of my water lines running to my throttle body looks like its getting a little too hot? its bubbling out from where the hose connects to the metal pipe going between the throttle body and the engine…
