so I did some work on the car recently.
I got new axles and a new half shaft
new honda trans fluid and new axle seals
I got the subframe swapped out and the alignment done. so the car is now sitting correctly. (sorry no pics of this)
best $11 I ever spent
I finished my exhaust finally and got my cat deleted. custom 2.5" test pipe everything welded up nicely and ends at my 2.5" truck muffler lol
finished up my ram air for now
plugged off my antenna hole
deleted my glare guards from my fog lights (i love this mod)
driver side is before and passenger side is after the glare guard was removed so you can see the difference
and last but not least!!!
MY OEM FRONT LIP AND EK SIDE SKIRTS!!!
and today I spent all day trying to figure out why my car wouldn’t start. turns out the main relay’s fuse is shared by the alternator solenoid valve on the underdash fuse box. and the damn fuse was checking good on the continuity test but was indeed blown.
This is my car. I didnt bother to show all of the stuff I did cause I changed a lot and sold a lot.
currently I am working on making caps for my ek side skirts and continuing the sound deadening removal.
I am also working on a front splitter and canards and a rear diffuser.
I also got a b16 head and b16b cams and I will be collecting parts for my poor man type r build
I am also going to be ordering my legend front brake upgrade this week so stay tuned.
as far as specs on the car, here ya go.
Engine:
95 GSR stock everything
USDM type R header
full 2 1/2" exhaust 2 1/2" truck muffler for the street
custom ram air intake
throttle body coolant delete
fludyne radiator
bwr slim fan
custom engine harness made by me
full wire tuck and ac and power steering delete
Chassis:
energy suspension sway bar bushings
k-sport gt pro coilovers for the dc2
dc2 front forks
skunk 2 rear lower control arms
beaks rear lower tie bar
energy suspension radius rod bushings
power steering looped and valve body reworked
jdm shit fake mugen front strut bar (this is only temporary I have a ctr strut bar I am going to bolt on)
megan racing rear upper strut bar
custom trunk strong bar (will be remaking this)
cut bumper supports
exterior and wheels and tires and brakes:
oem 92 front lip
Carbon fiber hood (not sure of the brand bought it used)
98 ek side skirts
plexi glass rear quarter glass (waiting on my hatch glass)
windshield wiper delete
hatch wiper delete
carbon fiber side mirrors
konig minuz 15x6.5" +45 offset
stree tires 195 50 15 pep boys tires
track tires 205 50 15 falken azenis (for now)
stock brakes currently (remand legend twin piston front calipers and 11" rotors for the front next week with remand stock da calipers and new rotors in the rear)
Interior:
97 itr non srs steering wheel
92 GSR cluster
Piolot shift knob
sunpro oil pressure gauge
custom bape fabric on door panels and shift boot (done by me)
gutted interior except dash and door cards and seats
no blower motor
no heater core
no ac condensor
stripped inner dash
chassis harness has been stripped of all un-used wiring
I am currently working on removing my sound deadening and removing as much weight as possible
future mods include buddy club racing seats and rails, 6 point cage with seam welding the entire chassis, asr subframe brace and 24mm sway bar, energy suspension front lca bushings, new oem ball joints, arp wheel studs, real tow hooks (undecided on brand) skunk 2 front and rear camber kit etc…
