Hood Dampers
I know people on here have put on hood dampers but i also know those old threads dont get looked at or responded to… So can anyone tell me where and how they mounted up their hood dampers? pics would be really helpful.
Thanks in advanced for any knlowledge shared.
What type of hood dampers are you talking about?
i had a set of the tein dampers that were made for the s2k,they bolted up to the middle bolt on the fender and where the hood is mounted to the hinge
that looks sweet anymore pics?
yea more pics plz:read:
i have a set of teins that was made for a dc2, made it bolt up to mines perfect, looks good i love it lol, will get pics as soon as i can
this is the only other pic i took when i had them on,hope it helps somewhat.they come with little plates for only 1 end,the plate bolts to the hood hinge,also i wouldnt recommend using these with a cf hood,pretty hard to shut with the hood being so light.on an oem hood it should work nicely.i made no modifications to them at all,they were made for the s2k but happen to fit on the g2.
how much did they cost? how long are they fully extended and full compressed. im wondering if i could just find a set of trunk dampeners that are the same length and moddify them.
they go for around 130ish i think i picked up used for cheaper,idk about the length,id check but i sold them awhile ago to another member on here.they install just about the same as hatch struts but you might have to fabricate a plate to bolt it to the hinge.
I found these on Ebay, never really read up on them just thought you might be interested.
http://cgi.ebay.com/ebaymotors/90-93-ACURA-INTEGRA-GAS-HOOD-SHOCK-DAMPER-LIFT-KIT_W0QQcmdZViewItemQQcategoryZ42611QQitemZ270101968000QQtcZphoto
Back from the dead, I really want to get a set. My hood props plastic mount broke, so I want to get rid of it all together.
What if you have a carbon fiber hood? Wouldn’t it go up to fast becayse theres not enough weight?
I know the passwordjdm shocks are adjustable, so if you have a CF hood you can reduce the pressure. Nobody wants to get knocked out by their own hood.
Yeah, get the Passwords, S2000, like $130
Does anybody have pictures of the S2000 dampers installed?
+1 for some f’n pics
Turbo we are never gettin pics, unless I order a set.
I ordered a set of these…
http://cgi.ebay.com/ebaymotors/90-93-ACURA-INTEGRA-GAS-HOOD-SHOCK-DAMPER-LIFT-KIT_W0QQcmdZViewItemQQcategoryZ42611QQihZ017QQitemZ270133037341QQtcZphoto
they dont fit. So where are the people that have the s2000 or DC2 setups???
what makes them not fit? have you contacted the seller? just wondering since it says 90-93 integra…
They hit the hood, if you try to close the hood it sits up in the rear.
