How much can 370s do???
just curioius about how much boost 370cc injectors can handle? 10psi, 14?, 16?.
josh
Depends on the motor you have
Based on a b16a at 160 flywheel HP, 370cc injectors should be able to handle 14 psi.
However, proper injector size is calculated by HP you intend to run as well
The issue will be The factory ECU has trouble idling anything over 310’s.
very true!! friend put a set of 370 in his SI with a drag kit car had serious idle problems and ran real bad. even trying to lean it out with the v-afc didn’t help. so he’s running stock injecotrs with 6 psi. runs like a champ now.
