I was wanting to now how i could make 200 plus whp out of my B18 ls motor. I have seen a b20 vtec make 200 whp but is it posssible to make a b18 ls motor. if so what are the main parts i should be looking at.
Change the Rotator Split to a bigger size
Add some Octane Booster ( Dale Jr. Edition)
Get rid of your muffler bearings
Or you could just SEARCH!
Search the website, this topic has been covered many of times, and after you have done that, then ask the questions, if there is any left to answer
give me 15,000 JUST for the motor and dont ever expect to drive it outside of a track. Oh also expect routine maintenance JUST on the motor to go up about 20 fold. You will need to completely dissassemble and reassemble the entire motor about every 500 miles or so to inspect for failure(s) unless you want more damage due to extended use with a failed component to occur
so just let me know when you’ll be dropping it off with me
i wont hold my breath
didnt 1 guy have well over 200hp on a b20 on here? like 230hp i think it was? i think its gotta be possible if you had ridiculous compression, lumpiest cams you can have made(prolly wont find them in production), like 1mm oversized valves. but the bolt-ons would prolly cost about the same as the engnie. side exit header and a race muffler if u plan to street it, jg or similar manifold, 72mm tb, nice 3" air bell or filter that flows better than any i have ever seen, either one would have to be mounted somewhere were u could get real cold air. it couldnt be too hard.
Call gude- gude.com. Them boys ain’t no joke when it comes to non vtec. They put in my boys ride 220 mhp with stock bottom. When he gets the bottom done he’ll be making around 240. Driveable, everyday, gas (premium). Yo, that’s sick indeed. Check it out! I Forgot! ALL MOTOR!!!
2FastLS check your mail.
Gude head pacage = ~1500. Gude throttle body = ~225. Skunk2 IM= ~240.
Stick that on a B20… Oh man. I’d be in tears.
huh? my attention is suddenly perked. any pics or vids of that car with 220hp?
Originally posted by IdntGlwIglisten
[B]Gude head pacage = ~1500. Gude throttle body = ~225. Skunk2 IM= ~240.
Stick that on a B20… Oh man. I’d be in tears. [/B]
I’ll be cryin like a little bitch!!
na! but call them up, look them up on the internet gude.com and get the number. they hook your’s up to aaaiiight!!!
yo man, you got some talent!
i can list a combo that makes rigth at 200whp for a b18b… its not cheap tho… it uses a aftermarket head and all… i know someone with one for sale built up like this pretty cheap (compared to the seperate parts prices)… makes me wish i had the money to buy it and id just throw it in my car
yea? list the setup. show some dyno pix too. ur crazy and not in a good way
here is a good setup from under 3000 that should make some decent power
Engine- Find someone who had a low mileage engine(<90xxx miles) who just swapped an engine into their teg. then buy it the longblock for 500
Intake- AEM CAI for 150
valve springs and retainers- 400 for install too
cams- crower 402s 300
cam gears- AEM 100
Throttle body - (still looking for a brand to reccomend) 250
Intake Mani - Skunk 2 250
Header - DC 250
Fuel Pressure Regulator - 150
fuel injectors - 300
fuel rail - 100
fuel pump - 100
1 hour of Dyno tuning - 175
TOTAL
engine-500
Valve springs/retainers- 400
CAI-100
Cams- 300
cam gears- 100
Throttle Body- 250
Intake Manifold- 250
Header-250
fuel pressure reg.-100
fuel injectors- 300
fuel rail-100
fuel pump-100
dyno- 175
total- $2925
1994 LS JG Engine Dynamics Pro Series Head
Brand new crower stage 2 cams
Crower dual valve springs w/titanium retainers
New valve guides
New Honda head bolts
New Honda head gasket
Port + Polish (intake and exhaust)
Racing Valve Grind
Skunk2 Intake Manifold
Gude Bored Throttle Body
Unorthodox Racing Crank Pulley
1994 B18B Block
2000 B16A2 Pistons (brand new and installed)
New bearings and seals
LS Connecting Rods
New piston rings
New wrist pins
ACT 6 Puck Clutch Disc
ACT X-Treme Pressure Plate
Lightened Flywheel
New Throwout Bearing
the motor was never ran… so we dont know exact power this motor will make… but the builder built a motor exactly like it before and it gave 203whp
if this is ur setup and ur streeting it then make sure u get a sprung puck clutch, the normal puck clutches only have engaged and disengaged(sp). the springs allow you to pretty much ride the clutch if u need to. not saying thats a good thing but sometimes u have to.
i wish i could buy the motor from him… he only wants $1200 complete and its never been run… but i dont have any money… barely got enuf to fix my motor up
damn 1200 for that set-up thats cheaper then Dh-racing. there cheapest B18 is 2300
thats why i wish i could buy it… but i dun even realy have money to fix my oil burnign problem right now… muchless a whole motor
a whole new motor = no more burning oil… =)
