Here is the How To on relocating your battery. A little disclaimer: There may a better way to do this, however this is the Budget Way. Read on…
Items needed:
2 guage wire 15 feet.
2 more terminals
Tool to punch through trunk floor.
Metal strip shown in picture.
1 large nut and bolt
3 screw type bolts.
1 large terminal for ground
Electrical tape
Zip ties
First thing is take the terminals off your battery. To remove, losen the two bolts on top of the hold down rods. Take that cover off the edge of the battery the holders are attatched to. Lift up and remove the battery. Underneath there will be four bolts. Taking these out is neccessary to take out the stock battery holder tray. Taking this out is not neccessary, but it makes the engine bay look clean. Picture below.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=102
Next thing you want to do is run the 2 gauge power cable from your engine compatment to the trunk. The easiest way to do this is use the gromet right above the ECU. The picture below shows what I’m talking about. Push it through from the inside and you’ll be able to grab it from the engine bay.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=112
Next you’ll have to pull the carpet and run the cable down the side of your car. Be carfull pulling your carpet, you don’t want to break the plastic peices in your door jam. Below is a picture.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=113
Now, I have a sedan. I’m not sure how you 2 door owners want to run your wire up under your back seat, so good luck. If you go out and buy a sedan, then I can help you. What I did was come up under the carpet as close to the door as possible and just run the cable under the back seat and pull it upbehind the back of the back seat. No picture of that. Once it was in there I ran it into the spare tire area and up at the rear of my trunk. Pictures of that here.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=107
Once I placed the battery where I wanted it, I took it out and punched holes through the trunk floor using an Air Hammer. The Air Hammer went through like butter. Then i used the two screws to bolt the metal bracket down.
On the metal bracket, ACE sells those as straight 3 foot and 6 foot pieces. They cost a few bucks and are very easy to bend. I test fitted my piece and thats how I got it to the right size.
Pics Below.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=110
Now, YOU SHOULD NOT HAVE YOUR 2 GUAGE HOOKED UP YET. DO NOT HOOK THE 2 GAUGE POWER WIRE TO THE BATTERY. If you do at this point, you could touch a ground with it and…well…thats bad.
At this point I put the terminals on both ends of my power wire. I picked them up at NAPA with my 2 guage wire. Here is where the big nut and bolt come in. In the engine bay, you want to put the bolt through the stock terminal and then through the new one. Tighten the nut down until you’ve got a solid connection. Wrap in electrical tape and zip tie in place. Pic of the finished product below.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=106
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=103
Now, again, you should not have hooked up the battery. Take your stock gournd wire which I had to cut about 18 inches from the terminal, and add the Heavy duty terminal to the other end. I ground mine in right below the Tail Light, but any spot will do. Just make sure that the paint has been taken off in that area. It may be hard to see, but the brass connector is my ground. Picture below.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=109
Once the ground is hooked up, check all your connections and put the power on the battery. Wa-La you’re done. If you’re curious about the second wire comming off my Positive Terminal, thats for my amp. Only one ground is needed.
Below are a few more pictures and the first one is from right above the battery to demonstrate how much room there is with my large sub box. The battery and battery box are stock.
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=108
http://communities.msn.com/dayuiz/outside.msnw?action=ShowPhoto&PhotoID=111
Remember to that you’re gonna have to reset your ECU. Email with questions.
_Steve
dayuiz@hotmail.com
AIM: DAYUIZi
Yahoo: dayuiz
Neil, Please add to Teg Tips**
