In Wes’s method he used a short socket as a “catch” for the pin but I found that technique frustrating and ultimatly useless. Instead of a short socket to “catch”, I used a spindle nut I had kicking around. It grabbed onto the round part of the shift linkage much better than a freakin socket. Once you’re down there, you will know what I mean. The short socket just spins and wobbles with every turn of the C clamp. The axle nut stays put and voila! A few turns, no hammering, no jacks or punches…Once it was out almost all the way I just grabbed it with a good set of vicegrips and wiggled it till it came free.
Thanks to that guy Wes Vann for the basic idea. Hope it helps someone else in the future.
thank god I found this. Thanks a million. I’ve been trying to force the pin out with different screws and it won’t come out. I think that clip holding it in is still on it. Thanks man.
I’ll share my secret will all of you to take this pin out. Use a spare a/c compressor bolt that attaches the compressor to the a/c bracket. The head on that bolt is a 12mm so it give you a nice size head to strike with a hammer and the diameter of the bolt is slightly smaller than the pin so it will pass right through.
because a lot of punches are too long. If you are not baller (like most of us) and dont have a lift, it is hard to swing a hammer 2 inches with enough force to knock the pin out.
lol yeah tell me about it when I did it I was laying on a plywood on the ground with gnarly-looking spiders walking next to my head :uhoh: I did it with a mini-sledge also known as a BFH. The 8mm punch was ok, think it cost about $15 tho. Much harder for me driving the new pin in that tight bitch, er,… I mean, newer tighter bitch pin in because the hole didn’t line up and I didn’t want to hurt her with my BFH :giggle:
that kinda reminds me of the scene in Kill Bill 2 where The Bride uses Pai Mei’s techniques to punch her way out of a coffin, and then digs through six feet of dirt.
Or, unless you absolutely must get that out, just grind the head off the the pin before it, where the linkage swivels. And replace it with a bolt and nut…did that when i replaced my trans, been workin just fine of course my trans that i bought was taken out the same way lol, so the bitch pin was never touched…
