how do i wire up DSM 450cc and resitor box. plz help with pics…
g2ic Turbo Guide, at the top of the forced induction forum.
All you have to do is cut the little plong or guide on the inside of you da wireharness plugs and they plug right up! Resister box is alredy wired in if you have a 90-91!
thanks alot. i wish i had pics. so all i do is cut out the old plong?
thanks alot man!
i suggest depining the harness plug at the driverside firewall
makes it look stock
how do you do that? i got my injectors in, dont know if they work yet so i need to wire up the resistor box. they really dont have a good write up on the stock resistor box
so do i just cut off the green plug and run the wires to the ECU and injectors?
If your wire harness is obd1 then they plug right up, at least they did with mine! Other wise cut out the little prong on the inside of wire harness injector plugs!
i have a 93 gsr so it is obd1. so it will plug right in?
Yeah, mine did!
pics plz? i like to work off of pics for some reason? that would help out alot
Here is a pic of the dsm injector next to obd1 harness that has not been cut!
And it plugs right up! As far as the obd0 harness i dont have one laying around but if it doesnt plug up then cut the little point out!
thanks. actually i already have that figured out. im tryin to get the resistor box wired up. thanks tho
do i need that black seal that sits on top oif the injector?
Ya, it would help!
thanks, you wouldnt happen to have the resistor box wire up on pics? anyone?
Nope i sure dont man!
