OK first off I am in the process of building a 91 Integra… I am going to be doing turbo… I would like to run around 12-13 sec (if possible)… Now I was recently offered a fully rebuilt 91 LS B18a1. I want to know if the way that this motor was built if i can handle boost and acheive 12-13 secs… I know right off hand a few other things I am going to do other than whats already done to the motor such as…
stage 3 clutch, lightweight flywheel, head bolts, vtec water pump, vtec timing belt, starter, 120 amp altinator, engine mounts, stage 2 or 3 axles, differential (tranny) skunk2 intake manifold, and hondata on board fuel managment system (S200)… (AND IF ANYONE HAS ANY OTHER SUGGESTIONS)
ok now for the list of things done to this motor…
The motor has been fully rebuilt and has no miles on it… It has a resurfaced flywheel, polished crank, new main seal, new main bearing, new rod bearing. .040 pistons (OEM), new rings, machinced, bored, honed, new head gasket, milled head, 3 angle valve job (valve springs), skunk 2 dual valve springs, new valves (16), new seals on top end, new timing belt, new cam seals and O-rings, new water pump gasket, new thermostate and gasket, painted valve cover, head, and block, ecu 90, wiring harness, tranny, clutch (stock and used), axles (stock and used), altinator, power steering, mounts, distribuator, new ngk plugs and wires… Filled with 100% Full synthetic oil and a few more things i am sure…
The guy wants $1300 for this… SHOULD I BUY IT??? remember i want to turbo it… Can it handle it and could I drive it as a everyday driver at 12 PSI??? Is there anything that I should worry about with this setup with turbo…
Any and all INFO helps… Thanks for your time…
I will post pics of the motor tomorrow…
