ive been lurking around on the website alot latley gathering some info…watching some peoples threads as they build there cars…
figured its time…since i started doing somthing tonight figured i would post some pics…
92 LS pretty much stock at the moment just dropped on some SE/GSR < only name ive ever seen them called someone correct me if im wrong…
day after i got it…
the terrible sounding exhaust the previous owner had on it when i got it…
interior is actualy minty fresh, its just torn apart in this pictuer…i need a new center consol piece though they drilled holes in it for toggle switchs that were useless and did nothing…
little bit of body damage, not to bad though
did something no one should ever doo…rattle canned it white
started on the body work sanded it down took out the back seats and started pounding it out a bit so there wasnt to much bondo to lay…
decided to lay down some primer in awaiting for actual paint. ill re do everything when i go to actually paint it…the spary paint looked so shitty i couldnt stand it anymore…i dont mind the work seeing as how im jobless and got nothing better to do at the moment except look for a job.
deffinatly need some side skirts to hide were the dumbasses jacked the car up on the panel instead of the factory jack points…
finally got some stock headlights thanks to : 4doorwhore : on here he has a red ls 4 dr…the idiots had the foglights wired to toggle switches, when all they really had to do was peel back some of the headlight loom and the fog wires were right there…
and a pic with the SE/GSR’s ?
since ive got this car ive pulled about some were between 30-45 yrds of useless wiring that went to really nothing…hooked up to power and then the other end was just dangling under the dash…the kids who i got this car from stressed that they wired everything up right when they swapped the motor…its been fun though finding all there screw ups…like my passanger window switch to roll the window down you go up and down doesnt work at all…driver side has to do it…its comical anyways on to what i did tonight
there was some dents and other things on my hood so i started puttin some body filler on it to smooth it out a little… anyways onto the pics enough rambling
