in the works
i have a obx top mount manifold, with a custom space plate to fit a 05 ram 2500 deisel turbo. with a custom 3’’ down pipe. its a set up ive been tryin to work on is it worth it. i wanna boost at least 25 psi
I hope you have a heck of a good engine setup to run 25 psi…
if you seen the da its in the finishing stages hopefully by the winter the motor will be done. i have at least 5400 invested in the motor build so far. not going for the rice look but . to at least pull 11 at the track and at 12 or 15 psi wip mustangs and others on the street.
no offense but 5400 isn’t that much for a build. i alone have spent around 1800 on honda parts alone. though that does include replacing almost everything including bolts. sounds interesting. though it better be sleeved as u wont be running 25psi if ur not
so far its 5400 , who knows what it will be in the end. i already have tomuch invested in this one car alone. i have 4 other da s im trying to work on lil by lil also… anyway 5400 is not bad and with a good tune should exspect high numbers and yes im am sleeved.
:fuckrace:
relax, i dont street race . just want the ability to pull off hard on others cars when i want to.
