injector help
was just wondering if i need to do something extra i put nos/holley 720cc injectors in my obd0 and yes they are low impendance, but the car wont start, it started once was real crappy then turned off wont start any more just wondering if i need to do something extra to get the car to start, any info will help thanks
Did you lean out the tune, you are super rich if all you did was add bigger injectors.
all i did was add bigger injectors the car ran fine when i started than wouldnt run when i finished aint that a b*tch
:ghetto:
Yeah…when your ECU is thinking its firing 240cc injectors…dont you think that might cause a problem just throwing in bigger injectors?
i only reason i through them in is becauyse a friend through in 550 with no problem what so ever, so i thought i would try but i have problems what are your suggestions
Get your ECU chipped and get your car tuned for those larger injectors…and do some more research before you just go throwing parts on.
