intercooler size
I was wondering if this would be sufficient for 300whp he says the dimensions are 25x6x2.5
Yeah, that should be about right, my precision is similar in size and is rated at 350hp. You should be ok.
yea that’ll suffice, cuz my da srt is about da same and it can handle up 2 300/400 hp i think so your good
that looks like an ssautocrome fmic. if it is the core is 3.5" thick, not 2.5".
no ssautocrap, its a spearco, if you look at the pic you can see remnents of where it use to say spearco
there intercoolers are top notch. there manifolds suck.
I ran an IC like taht, ecept my core was 18"x6"x3" Overall length was 24"
I hit 270whp easy and it was still cold on the cold side after 7 dyno runs
did you have to cut the bumper support at all to get it to fit?
I’m running the JDM support so no. but looknig at where the JDM one hangs down vs OEM. Yoiu wouldn’t either sicen tehy both hang down teh same amount etc.
and final question is whats the difference between a finned intercooler and a bar and plate intercooler?
Tube and fin are light, but dont have much thermal mass. So at low speeds it doesnt exchange the heat very well. They still work well.
Bar and plate (which I would say to get) have a higher fin density and are better at exchanging heat. Because they have a greater mass they act like a heat sink. What a heat sink does is soak up heat when there isnt any air flow and when there is air flow the heat is released.
so i guess with that a bar and plate intercooler would be better to have then a finned intercooler, anyone know by looking at this one which category it falls under?
im guessing this would be a bar and plate because of the front design, if it were a fin design then the solid pieces on the front would be a little more round correct? but this one is a bar and plate because it is flat
turbo project is cancelled so it doesnt matter
GREAT buy. PTE itnercoolers are awesome!! you won’t be disapointed
Dam thats nice! Excellent choice.
its heavy as shit, and i have absolutely no idea how im gonna mount it, but is sho is purty :clap:
yea dats definitely sexy
Haha the cast aluminum tanks make it heavy.
