The fog lights need to be cut and spliced. Those 2 wires that are in the back (red and black) are for the fog lights. Cut the fog light wires and splice the colors together. Then the corner light sockets just plug in.
Also, make sure you just tape up the non-flashing peanut bulb’s sockets or something… you wont need them. You’ll want to use the flashing corner bulbs in the one pieces…
Alright, cool. I get what I did wrong. I thought the 1pc’s were a direct plug n play with the harness I already had…I almost threw those plugs they came with away. I think I know, but just to be sure, I need to wire up the plugs on the left, correct?
Where did you get the black silicone. I’m afraid the lights I’m getting won’t have it as new anymore so I will try to reseal it. What exactly did you get? and do? sry but i want to do this right the first time.
nissan sealer.
B6553-89915
thats what i used for my retrofits.
this was the best help i’ve gotten so far…neil you should really add this to teg tips main page instead of just the forums page
ahhh i think i messed up
okay i got a few newb questions…are the fog lights supposed to turn on with the fog switch? because mine turn on with one click of the light switch, they stay on when i hit the high beams, plus the side markers dont work but i can work with them later, my main worry is the one piece, the thing that bugs me is that my corner lights dont work, did i clip and connect the wrong corner wires? it all seems to be hooked up good, i got no dimming…i just bought the car and all the elecrical in the inside is all jacked up, i think its because when i got it, it had ngk #7 with no resistor, i think thats what jacked my interior up, the reason i added this is because im wondering if this can be a cause why my side markers or corner lights dont work? any help will be appreciated…man i hope the ambers are the fog lights because if there just running lights im gonna feel even more of an ass
Question
got a question for everyone that has installed the 1 peices
is the fitment the same as the usdm ones? cause i installed mines last night and i got a bit of a gap near the center the hood on either side where the foglights are does that mean that they need to be moved over or that how they sit?
just wanna make shure
i have the jdm lights and im tryin to take the yellow fogs covers out so i can put them in my black ebay lights but have no clue sorry for the dumb question
im not sure how others have done it but what i did was use a flathead screwdriver and pry the metal holder / base separate from the headlights. it has 3 tabs the are bent inward and to put it back you just use a small flathead and bend the tabs back in when you position it.
thanx man im done
Anybody experience fitment problems with the headlights?
My right light protrudes forward by about 1/4" while the left one sits flush. I can’t push it in any further. Is this normal?
might be your bumper alignment or hood. pics?
delete
DOes anybody have a diagram 4 the side markers???PLZ NEED HELP
uhm… not really a “diagram” needed… there are two “peanut” bulbs from the USDM lights… the furthest one in the corner flashes… those are the wires you use for the sidemarkers as they’re supposed to blink…
