just got tunned by Xenocron (chris)
I just had my car street tuned by Xenocron last Thursday . I was previously running crome pro tuned by myself. I was tired of having a high idle and erratic idle behavior.
I called Chris for a tune. When I came to Chris’s shop I told him I was using cromepro. He mentioned a new program that came out which was called ectune. I said lets go tune with the new program. Chris did a few checks on my motor like timming and info on my setup. Once logged to the ectune program we were off and running. Chris told me to drive and he did the rest while i was driving. After about 3 hours which went by real fast, my idle was stable the car ran like stock. Chris set my vtec to open a lil early and enable step launch. My car running 18 psi. Next is to Dyno tune
Thanks Chris!!!
If your located in NJ, NY,PA, and CT go get your car tuned by chris (xenocron) he will do NA or turbo.
A lil info on my car
ls/vtec
port and polished gsr head
itr valve train
gsr cams
mahle 9:0 pistons
eagle rods w/ 3/8 bolts
780 injectors
sfp manifold
SC61 S Trim ported housing cold .63 hot 5 bolt
ZMAX intercooler
3 " down pipe
3" exhaust
turbosmart 40mm waste gate
turbosmart bov
turbo smart e-boost II
Z10 traction bars
competion 6 puck clutch
jdm ys1 w/lsd
i want to see the numnbers now. nice setup. what rpm do you reach full boost?
