nice ![]()
Me likey! ![]()
Nice! I’m guessing DTLA area ?
yeah i go to Mount Washington alot in LA.
Cool I work near DTLA area
oh cool i also like to chill at the rose bowl in pasadena
Nice is this under the suicide bridge?
its in pasadena by the rose bowl. not sure if it is the suicide bridge i have heard of that before tho. i thought that was in dtla?
i was just driving at night and they had everything lit up for a movie they said but I thought it looked cool all lit up so i took some pictures ![]()
Nice , btw is your integra a RS? Those are super hard to find !!! Super lightweight and durable.![]()
I got the rear speaker cups from an RS from my last junk yard trip. Did you replace them with speakers?
yes its a rs ![]()
i haven’t done anything to the speakers, i want to put in a subwoofer soo bad though
I’m looking for a new headunit because the one I have lost functional buttons. Unfortunately all the headunits have price increased 30% I assume due to tariffs scares. I wish I had bought them a few months ago. I just have 1 10" sealed box.
The Mrs. has 2 12s.
mine came with this
pioneer supertuner 3d.. it has aux and cd and radio but i swear it only gets the lame channels or i dont know how to use it properly because there is like fm1 fm2 fm3 but they all uave the same boring channels idk… at least i can use the aux
i hope i can splice in a sub so i dont have to buy a new head unit, taking apart the dash is scary as hell cause i dont want to crack anything
Word word …..!
You don’t have to take apart the dashboard at all. That DIN unit comes out if you’re able to push in the spring-loaded tabs on either side. If that doesn’t work, you can remove the screws for the entire center panel here. There are two screws on top-center, one on the either side of the top corners (once you remove the driver and passenger knee panels) and then two on either side. Once that is off, you should be able to see the tabs on the sides of the unit.
To use a subwoofer, (and make it an easy install without splicing stuff) you really need a headunit with subwoofer pre-amp outputs (RCA connections) and an amplifier to power the speaker. I can’t read the model number in the front of your pic to see whether it has those. Happy to step you through the process - I’ve done it several times.
Crutchfield.com provides new mounts and wiring harnesses too (for free) which makes the self-install even easier.
its a DEH-1200mp
i went to a car audio shop and he called it old school lol ![]()
ok thanks might do that soon
