1990 Acura Integra LS
Parts that made it to the garage
Engine:
B20
Eagle rods
JE Pistons 10:1
tb03 .42/.48 Garrett Turbo
Spearco Front Mount IC
Tial 35mm
Greddy BOV
Parts that made it in the car
Engine:
Replaced cam end seal
Engine:
B20
Eagle rods
JE Pistons 10:1
Tial 35mm
Greddy BOV
Engine:
slowly but surely
Exterior
SAAB Midnight Blue Pearl
93 Front Bumper
JDM 1 piece headlights
Shaved emblems
Smoked bumper lenses
93 tails
Interior
Generic Short Shifter
JDM Airfresheners (Squash)
Broadwaymirror
Suspension/Wheels/Brakes
16" Rota Grid w/ Kumho712 205/45/16
Weapon R coils
Kyb shocks
Rear washer/bolt camber correction
Painted brake calipers and rotors
Engine
Tired b18a
Dynomax exhaust
Akimoto airintake
Accel 8mm wires
damn Jon you got more mdos then me and taht bodykit. grr. next time I’m in van with my car we should meet up man. would like to meet you. go and see Jordan too you know
1991 Acura RS
Exterior:
Saffaran Metallic Paint
92-93 front and rear bumpers
shaved antenna and emblems, color matched mirrors, handles, mouldings
Stanley JDM headlights with Polarg H4H bulbs
Removed fog light glare guards
Acura Vigor OEM spoiler
Interior:
Oil Pressure, Oil temp, and Voltage gauge custom mounted in dash bezel
Safc and Shiftlight custom mounted above Alpine CDA 7894 mp3 deck
Momo Race steering wheel and knob
Lenzo Pedals.
Engine:
3 inch Custom aluminum CAI with Neuspeed Ram Air Foam Filter,
1994 Intake manifold and Throttle body (4mm overbore and taper)
30 thou milled off head with mild port and polish
Colt Cams
AEM cam gears
B16 dual valve springs
ARP Head studs
MSD 8.5mm Superconductor Spark plug wires
LS valve cover with gold vein powdercoating
P73-A00 pistons (USDM ITR)
Fully balanced rotating assembly
block decked 10 thou
Type One Racing 4-2-1 header
Carsound Hi-flow catalytic converter
RSR Ex-Mag exhaust
PYR ECU program
B&M Fuel Pressure Regulator
APEXi S-AFC.
Moroso Oil catch can system
removed powersteering
Suspension Modifications:
Neuspeed Race Springs
Koni Yellow shocks
Neuspeed Front tower bar
Ingall¡¦s Posichange front camber kit.
Suspension Techniques Rear Sway bar
Vibrant Rear tower bar
Vibrant rear lower tie bar.
Wheels and Tires:
16 X 7 ADR Jazz (black chrome)
Dunlop 205/45/16 SP9000
Audio:
Alpine seperates
Pioneer rear speakers
Kicker Comp VR 12 sub
Alpine Flex 5 amp
Alpine mp3 deck
EDA9,
is that a shift light? if it doesnt cause awareness for shift points it has secondary use as an emergency cabin light. ![]()
Ooh that Mango… that was beautiful man! :rockon: :rockon: :rockon:
Well sh*t, I guess I’ll chime in as well.
Engine Modifications:
Golden Eagle Godzilla Sleeved Fully Balanced B18C1 Block Bored to 85.5mm (2.0L)
Arias 85.5mm 12:1 CR 2618 Alloy Pistons
Eagle Rods
ITR Crankshaft
ITR Oil Pump
Mugen Baffled Oil Pan
ARP Head Studs
ITR Head with Portflow Headwork (multi-angle radius valve job, deshrouded valves, bronze valve guides)
Toda Dual Valve Springs
Titanium Nitrated Crower Titanium Retainers
Toda Spec B Cams
Toda Gen 2 Cam Gears
Toda Timing Belt
ITR Intake Manifold
Hondata Heatshield Intake Manifold Gasket
RC Engineering 70mm ITR TB
RC 310cc Injectors
BBK 255lph Fuel Pump
STR Competition Fuel Rail
B&M CommandFlo Fuel Pressure Modifier (45psi)
Toda Program OBD-1 P28 ECU
Apexi V-AFC (VTEC x-over @ 6600rpm)
MSD SCI-L Ignition (Rev Limit @ 9400rpm)
MSD High Vibration Coil
MSD Pro Distributor Cap
STR Cam Seal
Custom Polished Valve Cover
STR Polished VTEC Purge Solenoid Cover
Greddy 1.3 Radiator Cap
Mugen Thermostat
Mugen Thermo Switch
Optima Deep Cycle Battery
Stinger Platinum Battery Terminals
Transmission:
GSR YS1 Cable Transmission
G3 GSR 5th Gear
Quaife ATB LSD
Exedy Organic Clutch
8.8lb ACT Prolite Flywheel
Tenzo R Short Shifter
JDM ITR Shift Linkage
Energy Suspension Shifter Stabilizer Bushing Set
Intake Modifications:
RS Akimoto Funnel Ram II Intake
Custom Cold Air Extension
Exhaust Modifications:
Toda 4-2-1 SS Header
OBX-R Resonated Test Pipe w/ custom 2.5" flange
RS*R Cat Back Exhaust
Suspension / Handling Modifications:
Skunk2 Coilovers (lowered 2.5")
Koni Yellow Adjustable Shocks
Specialty Products Camber Kit (Front & Rear)
OBX-R Front Upper Strut Bar (Polished)
Suspension Techniques Front & Rear Sway Bars
Focuz Rear Lower Tie Bar
EM Racing C-Pillar Bar (on it’s way to me)
Wheels/Tires:
17"x7.5" Volk SE-37Ks
205/40ZR17 Kuhmo Supra ECSTA 712s
Brake Modifications:
Goodridge SS Braided Brake Lines.
Custom Lighting:
Clear Bumper Lights
Stanley JDM One-Piece Headlights
PIAA 1400X Fog Lights
Cleared out 92-93 Tails
Other Exterior Modifications:
Tinted Windows
Zendar Roof Mount Antenna
Shaved Stock Antenna
Shaved Emblems
New Paint w/ Match Painted Moldings
Custom mesh in front bumper
Interior Modifications:
350mm Momo Monte Carlo Steering Wheel
Momo Short Leather Shift Knob
Razo Pedals
White/Ice Blue E-L Indiglo Gauges
Auto Meter Phantom 5" Monster Tach w/ Blue Shift Light
Phantom Air/Fuel Ratio Gauge & Mechanical Oil Pressure Gauge in Auto Meter Dual Pillar Gauge Pod
Genuine Acura Arm Rest
Sound System Modifications:
Clarion DRX9275L Head Unit
Clarion 18-disc changer
Alpine 9 Band Graphic Equalizer
Precision Power A600 & A300 Amplifiers
Precision Power EPX-205 Crossover
Phoenix Gold .5 Farad Capacitor
MB Quart Comp RSB 218 Front Mids & Highs
2 JL Audio 12W3-D4 Subwoofers in Custom enclosure
2 JL Audio TR525-CX Coaxials for Rear Fill
VB2 Sound Deadening Material (whole car)
WHEW…that’s it.
Now THAT’S a list. Start on that yesterday, didja?
Re: Re: Re: Re: Re: Just what is your mod list
Originally posted by B17A
What snail were you running? How much of a gain do you expect to see with the precision?
I had a garret t3/t4 57trim, which is a good size for our cars but I decided to go a little bigger. The pt61(good for over 500whp) supports more than enough power I want.
:mad: Way to go Dan, come in here like a bully and make all of us look bad!!
j/k I didn’t get my ride in your car at WCM ![]()
Ryan: Remember, the car is yours in a few years, hehe…
Tchleung: Cool, that’s what I want to do, and a photoshoot too. But I won’t be back in Van until January, so give me a holla then.
Max: Looks like you have a list to catch up on ![]()
ttt!!
ShadyB, startroops, and mysel all ahve the same tyaste it looks like…
Startroops
ShadyB
Me(Tchleung)
Oh taht’s right. I’m missing the OEM bodykit they btoh have. GOD DAMN LOL
i was waiting for dan to post. sheesh nice novel dan:p im glad to see that pic made this thread. looks like ill be forever known as the guy who let the guru’s wife shave g2ic in the back of my head:p
and Jon i know dood im excited;)
Ya I put a scented blue leaf in mine, how bout that for some modification. Smellsssssssss goooooood
gotta jump on the bandwagon too…
Year: 1990
Make: Acura
Model: Integra
Edition: LS
Engine: B18A1 swap auto-manual conversion
Exterior
Flat black spray can paint job
(gonna redo it properly soon)
JDM style fender w/ sidemarker
JDM mirrors w/ switch no relay
92-93 tail lights
92-93 rear bumper
Removed rear wiper & firewall plug covered
Hood pins
VIS RS bumper cover
Removed bumper lenses
Removed front mudflaps
Shaved power ant.
cf hood comming soon…
sedan door handles comming on soon…
Interior
momo race steering wheel
91 GS seats
92-93 gauge cluster
Custom dash bezel
Shaft style shift knob w/ carbon fiber strip
Razo gas pedal, ricer brake pedal, some other carbon fiber clutch pedal. brake & clutch pedals have been covered with grip tape.
Removed rear seat
Custom 4 point driver seat belt
5" auto gage black face tach w/ shift light
'89 crx si alloy 14’s on yokohama radial 388’s
oem struts with H&R sport springs (i think)
Ebay rear strut bar
Ebay front strut bar
Custom c-pillar bar
Custom strong bar
'99 gsr wrapped with some tires… dunno what kind… comming soon…
Custom lower tie bar comming soon…
Performance
Custom cold air intake
Aftermarket clutch &/or pressure plate (dont know what kind… just know i spin second, and chirp third
DC Sports ceramic coated 4-2-1 two piece header
RS*R “old school” exhaust
OBX 10.3mm spark plugs wires
Ebay short shifter
Battery relocation to behind passenger seat
Neuspeed shifter bushings
Custom polyurathane motor mount inserts
Ground kit
B18B intake manifold going on soon…
ICE
alarm system
pioneer deh-14 cd deck
pioneer & infinity speakers
Miscellaneous
RIDE brake cylinder wrist band
TEAM ULTRASPEED decals
custom G2IC.com decals
5hp each yo ![]()
[IMG]
more pics…
http://www.imagestation.com/picture/sraid75/p0f06aa547a973d5341c1b1b148d7ada1/fb516a64.jpg
http://www.imagestation.com/picture/sraid75/p9ca6528edae7024ef42bfc40514fba64/fb55f80d.jpg
http://www.imagestation.com/picture/sraid75/p6840a2fbf3db9e2faa51e25e87c06434/fb55f809.jpg
http://www.imagestation.com/picture/sraid75/pc09139c9ba29341eba4f576cb1db0c07/fb516a67.jpg
(yes i know i need to get new pics…)
will post more if i forgot anything…
Did the sidemarkers not come stock in Canada?
they didnt’ come stock on any car but JDM ![]()
1990 RS 4door Rio Red
Exterior
-92 gsr rims
-92 front bumper
Interior
-2" oil pressure gauge
-2" water temp gauge
Stereo
-Pioneer 9200
-Pheonix gold ZX350
-JL w3 10"
Suspension
-aerospeed coilovers
Engine/Exhaust
-B18a
-Billet knife crank
-B16a2 pistons
-Eagle rods
-prodrive oil pump gears
-9lb clutchmasters flywheel
-ACT extreme pressure plate w/carbon kevlar disc
-undecided on cams as of late
-generic short ram intake
-HKS hyper catback
i’ll get pics asap
1990 GS
Exterior
-classy flat black hood
-horizon grey driver fender
-precision scratched front bumper that doesnt fit right
-1 mudflap
-1 pieces
Interior
-stock
Suspension
-weapon R coilovers
-agx
-some bars
Engine/Exhaust
-stock
ok i guess ill join the list, even though i hate posting after mango and dan since my mods look more like a grocery list compared to theirs!!!
1993 ls 5spd
exterior:
repainted original sparkling black
clear corners, bumper lights
JDM black hood with “H” symbol
93 stock lip painted body color
clear tail lights with top painted red like 98 prelude
interior:
focuz short shifter
indiglo gauges
indiglo pedals
black front seats
engine:
just axle back exaust took off the intake
suspension:
sparco 2.25 drop springs
front ingalls camber kit
rims:
1999 civic si rims (so clean)
gsr rear wing with led
stereo:
pioneer xm ready deck dont mnow the #
pioneer 5.25s in front 6.50 in back the brand new 4 way 220 w
rf 250 amp
1 mtx 10 in hatch enclosure
i have a newborn so limited budget!!!
about to get brand new alarm, power locks
