i live in Quebec city and i really wanted to put the turbo kit on my car. Im still struggling wheter i wait for summer or not…
does anybody know anything that can go wrong for an aftermarket turbo setup during winter (temperature sometimes go below 25 celcius or -13 fahrenheit)
its a T3 and with 28inch FMIC
probably the only thing would be that with air that cold you could run lean. i guess just have a really conservative tune ready, thicker oil and you’ll be fine. just my .02
try to find a 0w-40 synthetic or 0w30, that way you have AWESOME cold start up weight and you still have a nice thick protection for tubo and engine parts when the engine warms up :idea:
I dont know too much about aftermarket turbo kits on the b18 b16 engines, but Ive been shopping for a Talon TSI AWD, my buddies all have them with 16g 18g and 20g turbos, they run them all winter. None of them have had a problem. they just have to use the SAFC and dataloger to tune the fuel system so it runs right in subzero temps. Just make sure you are running a good oil, and dont do any hard pulls untill the car is warmed up. Might want to set the turbo timer to 1min + aswell.
for cold starts just have a switch set-up on the fuel pump, crank the car untill the oil light goes out then turn the pump on and start it up. 10w-30 is the thickest I’d go when the temp drops below freezing.
I would think it would be just fine as long as you use a thinner oil then you do during the summer, there are all kinds of cars and trucks that come stock with a turbo and you dont see them parking it during the winter, I think as long as you use a thinner oil like 5w30 and you let it properly warm up before boosting (which you should do all year round) it will be just fine
The suggestion about putting in a fuel cut is a good idea, but I do have a question about that, is it bad to let the injectors dry fire during that time the fuel is off and the engine is turning over that long?
