Well this is prettymuch a re-trace of the history of me getting my DA until present day.
I’ve been into Hondas since I was like 12-13 (am 24 now). But when the time came to buy my last car, I was bitten by the Subaru bug and I very nearly picked up a 2000 Subaru 2.5RS. After test-driving it and feeling the power virtually disappear at 5,000RPM… I realized how much I would miss the high-revving world of Honda…
I decided I didn’t want to get the tried-and-tired Civic Hatch, or the DC Integra… I do like EK Coupes, but still wanted something different… It was then that I really noticed the DA and how un-common it is around my area. After about a week I had plans to go see two different DA’s. Upon calling the owner of the first car, I found it had been sold. Meh… So I called on the second one and went to see it.
I instantly loved it. The next day I returned to the guys house with $2650 in cash and drove my baby home.
I’ll first list the mods, then will document the history with pics that I have. Motor has 0 miles on it as it was just barely installed, and still waiting to paint the shell.
Exterior:
LS Mesh wheels; wrapped in BF Goodrich G-Force Sports in 195/50/15.
OEM Front License Plate Removal Plugs
Acura Legend Yellow Fog-Light Mod, with the Fog-light switch mod.
S2K Style Antenna
Suspension:
Skunk2 Pro-S Coilovers
SuspensionTechniques Front and Rear Swaybars
RevoTechnica Front/Rear Camber Kit
HaSport Billet Aluminum MotorMounts
Motor, freshly built.
Block:
- B18B, 81.5MM bore, fresh from the machine shop
- Micro-Polished B18B Crank
- BC B18B Rods w/ ARP 2000 studs
- JE Pistons, 11.6:1’ish compression
- Calico Bearings all around
- ARP Main Bolts
- ARP Headstuds
- OEM ITR Oil Pump
- GMB Water Pump
- Gates Racing Blue Timing Belt
Head:
- '99 B16a3 PR3 Head
- Fresh 3-angle valvejob
- '00 JDM ITR/CTR P73 Cams
- Skunk2 Pro-Series Adjustable Cam Gears
- ITR Lost Motion Assemblies
- ITR Dual Valve Springs/Retainers
- ITR P73 Type-R Intake Manifold, port-matched to theottlebody
- OmniPower 70mm throttle body
- eBay 4-1 header; 2.5" Collector
- RS*R ExMAG Exhaust System
- CarSOUND 2.5" Hi-Flow Cat
Transmission:
'91 JDM XSi/B16 trans with 4.4 Final Drive
Raybestos OEM-Replacement Clutch Disk
Exedy OEM-Replacement Pressure Plate
B18B Flywheel, freshly balanced
Misc:
OEM Non-A/C Firewall plug
OEM Non-A/C Heater Duct
A/C Delete
P/S Delete with in-line filter
JDM One-Piece Headlights (soon to be installed)
GoldenEagle LS-Vtec Kit
First day; The Test Drive:
The next day at its new home; next to my hooptie:
After owning it for a few months, I did some absolutely necessary mods.
Skunk2 Pro-S Coilover Setup:
Installed:
Suspension Techniques front/rear Swaybars; Purchased from a g2ic member:
After the drop:
