LSD Motorsports manifold
anyone have any exp. with these? quality, issues, etc.
These are quality manis, I know that if you ever have any problems you can personally call and talk to mike, or message him on hmt. He has taken care of every issue that ever came up and their products are known to be of good quality.
cool thanks,
well I got the manifold (second hand) but now realise that there is a slight bow in the exhaust port flange. is this going to be a problem? reckon i’ll need it machined or will it still bolt up fine?
torque it down enough and use a good thick gasket and it should be fine… my ccfab is a lot worse then that and it only leaks in the one spot my exhuast stud snapped off. You can get it milled down some if you like, or if you find that its not sealing well.
