Map question
Im adding a turbo onto my B18a engine, do I need to get a different Map sensor or can the stock one support it?
What are you using for engine or fuel management?
Stock is fine. It can only read up to 12psi though. Any more than that and you need to upgrade to a 2.5 or 3 BAR map.
I will be using a E-Manage for fuel managment
Chip your ECU WAY better than e-manage. Also cheaper.
as long as your not using nothing, or a FMU
i thought stock map was only good up to 9 or 10 psi…
