Mapping help FOR LS Turbo
my friend is trying to make a Turbo LS. (b18a2)
he has drag 3 turbo kit w/ stock ls he has just 550cc injectors (90 octane gas) and he want 7.2 psi at first.
(for obd 0 - pr4)
and so does anybody have a safe mode map for this configuration??
or can anyone write it fos us?
What are you using to tune with? Crome, uber, neptune, stand alone? Mostly need to know what kind of map you’re looking for, even then if you found a map that was tuned on your equal setup it would not work the same as it did for the car it was actually used for. Xenocron has an excellent bin repository to pull basemaps from but you’d really need to take it to someone who could fine tune it for you, it’s not worth skimping out on the most important part of turboing a car.
http://www.xenocron.com/bins/
