mitsubishi manifold
any one know of a manifold that would bolt up to a mitsubishi turob?
You just have to find a manifold that has a DSM turbo flange on it. When you buy a manifold it specifies what turbo it bolts up to.
yea i know that. My question is :
Who sells a manifold with a mitsubishi flange?
Any company that makes manifolds.
dont know if this is true or not but someone said i could use a mitsubishi manifold for my car if i wanted to go turbo for cheap…they said the manifolds fit on the b-series engines…i tried to research it on here but this is the only close thread…im most likely wrong since there isnt any budget builders with it…but worth a try…
no
u can get a t3 manifold and buy an adapter plate for cheap, that is the best way to go instead of some specialized manifold
looksmyzrsOn, Yes they do fit if you redrill 2 or 3 of the holes, kinda scary though…
I have also heard that they directly fit the older F-series in the early 90’s accords, but definitely not a B-series. Going the adapter plate route isn’t a bad idea if you can save a decent amount of money on it.
http://bmcrace.com/products/adapters/
