I really like the Honda Integra Type R MOMO steering wheel (non-SRS), and I will probably be getting one soon. Has anyone else done this before? What would I have to do to wire up the horn? This is the wheel I’m talking about:
The wheel should work fine as long as you get the correct hub. I have seen this wheel on a RHD DA before. As far as the horn I would imagine it’s the same connector, should just be a plug and if it doesn’t match you can always splice it. Like I said though, get the right hub and the rest should be easy. It’s a good looking wheel, I like my Mugen wheel myself but would’ve went for the ITR next.
I searched for msteggy and i didnt get anything related to putting this steering wheel onto the DA…i wanna know too because i would prefer an OEM honda wheel with the CC controls on it then getting something aftermarket
I’ve asked a few people with da’s who’s put that on their teg. they said it was straight forward, bolts right on with no modification. But i’m not 100% sure as i haven’t done it. But i am planning on ordering one (as soon as i find a realy nice clean one). You just lose your cc features (which i took that crap out anyways).
i am sure you can find either an S2K wheel or something of that nature with the CC controls on it that looks better then a stock DA steering wheel…this is my new mission
I’m interested in the same wheel for my G2 as well. All I was told was that as long as the spline diameter is the same as the JDM ITR wheel, it’s a direct bolt on. Does anyone know the spline diameter of our OEM wheel?
I Swapped a 99 gsr wheel on my teg, minimal mods to make it fit. I’ll post pics when I get home. People said it couldn’t be done, but I did it and I like it.
From What I have found for the horn and the cruise, it is only 3 wires that are used, power, set/decel, resume/accel. the horn is tied to the pwr wire.
it’s just what i was looking for…i have the same wheel as you but i couldn’t fit into my car as the “teeth” space and also the length of the back of the steering is far longer than ours.
Can i know what modification u have done? is the modification done to the steering wheel or the steering rod?
thanks in advance. I need ur advice asap and pic will be helpful though.
