MOMO JDM DC2 on a DA
^Sweet!
Alan, I like the itr non srs wheel, but i like ur srs airbag steering better though.\Can you show me (if with pic) how and what modification that needed to be done though…such as cutting about half of the notches…there are “teething” on it…just need to know where to cut though. Thanks.
^That’s a beautiful picture.
very… it’s just so… sexy…
When installing the jdm dc2 type-r non-srs wheel do you need a steering wheel puller tool to take off the OEM DA steering wheel?
I have a 92 GSR with cc but I don’t need the cc. Is there an extra wire for cc?
xm8:
It depends on how long the wheel has been on. If it’s never been removed, then yeah. If it’s been swapped out before, then you may be OK. Just rent one in case.
The cruise control is actually 2 wires, one for set, one for resume. (or something like that.) If you don’t want it then you don’t need to mod anything. Just leave the wires alone & mount the wheel.
If you’re thinkin’ of removing the whole unit, then just mount the wheel back on the spline, (or hub adaptor) then remove the box from the engine compartment. I just tucked the cable out of the way until my wiretuck begins.
Lastly, if you want to keep the horn, try searching my thread “How to hook up your horn to aftermarket steering wheel” A bit of tweaking to the method may be required 'cause its a factory wheel, & not an aftermarket.
:getsome: :manual:
Damn you dug this up from the grave! Last post was in '05!
most of the time, it’s easy to just wiggle the wheel off…
[QUOTE=tegboi;1214783]
no signal return, gotta find all the parts for it though… as long as it fit, and i could bolt it down, i’ll still use my middle finger as my horn… haha
but really, no horn, no cc, no signal return… it’s :ghetto: but fine for me…[/QUOTE]
:jerkoff:
lat night i was try to put this on my teg but now my horn is not working??? we found out the horn is in the same conntor as cruise control?? how did you guy do it ???
maybe you need the aftermarket momo steering wheel horn signal plate?
there is no other way ???
have a jdm xsi da6 an this thread has helped going to get a wheel and put it on il get pics up soon!
Im gonna dig this thread up from the grave again anyone new put the non srs wheel on their da? Im gettin ready to do this and just wonderin about the horn? I stripped my cruiz for now cuz I’m doin a complete wire tuck.
