2-13-11
well picked up these
Started the day with draining the oil and making sure it wasnt knocking. after i got past that, i gathered parts like mad. by about 2pm i started working on the car.
dropped the oil pan and cleaned up and replaced the gasket, bolted it back on, and was good to go. Then went to the top of the car and took the valve cover off, all 7 bolts were ridiculously stripped so i rethreaded all the studs, and the nuts. Then i pulled the cam seal out and reapplied gasket maker to stop the leaking, and also replaced the §§§§§ o-ring cause that was shot to hell.
then i did the valve lash adjustment…holy shit was that thing out of spec. Someone didnt treat this motor well. when i pulled the cover it reflected how the oil looked, poor car. After i got the lash all set, i dug out my old A1 valve cover and cleaned it up and slapped the new gaskets on. got it all ready to mount on and realized i didnt have the fking nut grommets…
went to go pull the ones off the B1 cover…and SOMEONE fking 1/2 assed that shit. there were like 3, the rest were just squished rubber, or just metal caps… smh…
frantically hit up Efren and was able to bum the ones off the b20. Thanks again bro, ill order the new ones soon.
after i got back, i installed everything, and also my new spark plugs, also tried the PCV valve, but advance bullshit doesnt fit, and it didnt need it anyway. Finally bolted everything else back up, filled the oil up, and cranked her over. the motor noise was gone :), but i started noticing that it was smoking a lot from the bay… poped underneath and there was a FKING PUDDLE coming from the trans side…
so its already like 11pm, so i say fuck it and dropped it down AGAIN…fml. turned out when i pulled the old stiff ass gasket, it left 2 metal washers on the 2 studs for the main seal… so it wasnt bonding. After i got that all back up together and situated, filled her up AGAIN, and started her up AGAIN, and this time all was good :).
I want to do a leak down test and see if the valve seals are wearing out (which i think they are)
Also i replaced the ecu to get rid of the code, well this one is now throwing a code 43. I just looked it up and its saying fuel supply system? fuel pump is whining a bit… FML i cant win…
