My 93 ls build
these are pics from when i first bought the car. got it september of last year and its my 2nd da. 1993 ls with a jdm b16a sir 2 swap and a 90-91 ls trans. came with a carbon fiber hood which needs tlc lol. also came with kyb gr 2 struts and ebay coilover sleeves which ride surprisingly good. there were some flaws as i picked it up for 900. all the wheel studs were stripped and i had to replace them and the shift linkage was so bad i couldnt tell what gear i was in lol… got it fixed tho
the first thing i did when i got the car was pick up an ls engine… i like the b16 but it had no guts on the low end and top end was meh. so i picked up this ls for 200 complete longblock and spare parts came with so great deal.
i picked up parts for my lsv build ebay 4-1 header and feed line kit with some npr piston rings.
couldnt wait for me to do the swap so i threw on the header to try it out
did the lsv swap and it ran good. used the p30 pistons out the b16a and it pulled hard. but later i found an oil leak which the headgasket was the culprit of. and thats due to me just slapping it together without resurfacing the head… i know i know noob mistake. but what put it down for a good while was the trans blew lol… spider gears in my diff blew apart
here
the good thing tho was that i had bought a jdm y1 b16 trans a month before that from a kid for 100
and then after i put it in the head gasket was really eating up oil so i parked it and decided to get to work.
picked up some parts half size radiator from speeddady, h beam rods from godspeed (from my research they are the same as scat h beam rods, we will see. and for 320 ish shipped not a bad buy) also replaced the steel rod bolts they came with with arp 2000 rod bolts. adjustable cam gears from ebay. full race traction bar i picked up for 200 only test fitted. arp head bolts acl bearings. act streetlight flywheel (12.5 lbs) and a 6 puck unsprung clutch. new water pump and tensioner. no name b series 70mm throttle body and polished type r intake manifold
i also got type r replica seats and installed them. i also began switching the blue interior to black… hate the blue. got a black carpet and black 90 rs rear seats dont have pics of those tho
rebuilt my y1 b16 trans with synchrotech carbon synchros and a 4.4 final drive
after i pulled the motor
removed brake lines and front end
cleaned the block
also picked up some hoosier slicks 22.5 10 r 13
also went to stock on the headlights… hated the ebay one pieces the da came with
last night i began removing paint in the bay
looks good my man
thanks man. i was able to remove everything from the bay and work on the firewall today.
Great start with your built! OEM headlights look way better.
i looked at the engine pulled and said ‘please lord let him at least pressure wash and hand polish/wax that bay before he drops the engine back in’ low and behold, it’s getting fresh paint…WOOT…will keep my eyes in here to see the progress…good move bro
thanks guys i started welding the holes on the front headlight support area ahha and ran out of wire so ill pick up again tomorrow night. and yea im planning on using a high temp champagne gold paint for the block. and a similar champagne gold for the bay.
